Shut Up Legs
Down Under Member
All these years of cycling, and I never knew it was possible for cyclists to terrorise motorists. Please elaborate, sirA Triban 3 used for terrorising motorists.
.To the original poster: another tip for smooth gear changing is that when you're changing down a gear or more because you're approaching a hill, don't leave the gear change too late, otherwise when you do change gears, you'll have too much pressure on the pedals due to the increasing slope, and your gear change is likely to be a bit noisy and a bit rough on the derailleurs.
