Two new wheels... Why new wheels?
O Odyssey New Member 20 May 2008 #16 domtyler said: Two new wheels... Click to expand... Why new wheels?
OP OP Maz Guru 20 May 2008 #17 domtyler said: Your lubing your bike with MuckOff? Click to expand... I meant to say it's chain lube made by muck-off.
Yorkshireman New Member Location North Hykekam, Lincoln. 20 May 2008 #18 Does the gear cable run under the bottom bracket? (Might be a bit of muck in the guide). Or, is it time for a new cable?
OP OP Maz Guru 20 May 2008 #19 Yorkshireman said: Does the gear cable run under the bottom bracket? (Might be a bit of muck in the guide). Or, is it time for a new cable? Click to expand... It does - I'll check it.
Gerry Attrick Lincolnshire Mountain Rescue Consultant Location Lincolnshire (Halfway up England on the right) 20 May 2008 #20 domtyler said: Two new wheels, a complete new chainset and new levers and cables will fix it. Click to expand... Dom please be more responsible. One day a newbie will take you at your word and spend big wads unnecessarily. Have a care!
