roughrider
If the cable has broken inside the shifter this will be a pain; perseverance and luck will be needed, but eventually I managed to clear mine out with the help of a fine tipped slothead screwdriver. A bit of up/down shifting with push and pull of the frayed cable end helped too. Manual suggests replacement of the plastic guides if cable breaks off inside the shifter. I didn't - time will tell if this was essentialI was about to say, with the shifter set to the right gear the cable should simply slide out of the side. Otherwise you spend thirty minutes swearing. DAMHITK.![]()
