And don't even consider getting a set of these buggers!
http://www.wiggle.co.uk/p/Cycle/7/Transfil_Flying_Snake_Brake_Cable_Set/5110000356/
The outers are far too stiff and crack easily. Bizarrely, the brake cable outers have the wire reinforcements running parallel to the cable direction like derailleur outers, rather than the spiral casing used by every other brake cable outer I've ever seen. I thought I'd fitted them wrong first time round and I'm still not convinced they'd been packaged correctly. As you'd expect, they couldn't handle the brake lever forces and started splitting at the cable ends quick sharp. Easily my worst ever purchase!
