craig kennedy
I am a geek
- Maidstone, Kent
yeah ok no clue what you said, so googling now
Probably better if you don'tyeah ok no clue what you said, so googling now
So will any front mech with a trim function. All the yaw function does is prevent chain rub, surely?Yes. Depends on the groupset though, some (any SRAM groupset with YAW derailleur) lets you do it.
They do, but it's not a nice sound is it? I've yet to see a non YAW front mech that allows 22 noise free,usable gears, di2 excluded.So will any front mech with a trim function. All the yaw function does is prevent chain rub, surely?
Yes, but my point is that the reason cross chaining is advised against has nothing to do with chain rub on the front mech.They do, but it's not a nice sound is it? I've yet to see a non YAW front mech that allows 22 noise free,usable gears, di2 excluded.
Do elaborateYes, but my point is that the reason cross chaining is advised against has nothing to do with chain rub on the front mech.
Cross chaining is reckoned to weaken the chain and increase wear by subjecting it to excessive lateral forces. It also puts stress on the rear mech by pulling the guide cage sideways.Do elaborate
Do you not think it important that he understands why?I'm guessing all this somewhat off topic banter is doing is causing Craig more confusion. Quite simply Craig, if in doubt, don't cross chain.
Oh only reckonedCross chaining is reckoned to weaken the chain and increase wear by subjecting it to excessive lateral forces. It also puts stress on the rear mech by pulling the guide cage sideways.
Pretty much every gear used will put stress on a chain laterally so do you ride using only one or two cogs on your cassette?Yes, reckoned. I chose my words carefully since I am not an engineer. But seriously, that is the reason.Oh only reckonedPretty much every gear used will put stress on a chain laterally so do you ride using only one or two cogs on your cassette?
I imagine that would have been a Sturmey-Archer (or similar) hub gear and a beefy 1/8" chain. The hub gear was famous for being long-lasting and bulletproof (although if you had done some minimal maintenance it might have lasted you longer!) and the chains lasted forever too - partly because they were wide and heavy, and partly because they didn't have to do much other than roll in the straight line round two cogs.For years I had a bike that would be classified now as a hybrid, but with only 3 gears, using the old style lever.![]()
I never looked after it, and eventually it got stuck in 3rd gear so I removed the gearing parts, leaving the rest of it.
I never oiled it, never did anything and used the bike for long (15 miles) and short hops daily for about 8 years until it eventually fell appart.
Never did I have to replace the chain or rear cassette, nor did the chain ever come off?
