Gas meter Serial number.
U
User6179
The fitters fault then.
Any ID number for him on the meter. Will be on a small sticker on the side.
Yep, he copied the number down wrong, it has a bar code next to the number which I thought would be used by the meter reader when reading the meter maybe.
The thing is I always put my meter readings in online so I don't know if the utility company can read the meter or not, never had a bill from an actual reading from the company .
classic33
Leg End Member
If you need to take it further,
Gas Metering Team
Utilities Team
Usery Delivery
Stanton Avenue
Teddington
Middlesex
TW11 0JZ
Email: gas.metering@beis.gov.uk
Consumer Enquiries 0121 345 1218
classic33
Leg End Member
Not been read by the company since it was fitted?
U
User6179
I don't know because all my bills have been from my own readings that I input online, they may have read it but never had a bill from them reading it but I suppose if you keep your readings up to date they don't need to bill you from their readings?!
classic33
Leg End Member
They're required to read them at least once every two years. Whether you supply a reading or not.
U
User6179
They come once a month for the electricity reading and I chase them :laugh: because the cupboard is full to the brim, I don't know if they have already read the gas or if it is even the same guy who reads both but he has never went round the side after I told him he was not getting in to read the electric.
Levo-Lon
Turn it round...some count backwards and some just give you free gas..
It may be someone had a stolen meter. ...forgot to change it back if your a new tenant owner..
Tampering with a gas meter is an offence..but lots do and there is a big market for hooky meters
classic33
Leg End Member
They'd have scanned the barcode, which would have flagged the problem up.
They're not allowed to rely soley on your supplied readings, as they could be liable. As could you, for "supplying false readings", if their figure is higher.
