Garmin question
martint235
Dog on a bike
Welling
Garmin should save right up until the battery dies. How long were you out for, for the battery to drop dead mid ride?
What I would like to know is what happens to the feet climbed. When I look at my Garmin summery of the ride, it will say that I have climbed 1800 feet or whatever. Then, when I plug garmin into my laptop and transfer the ride to my Garmin connect thingy, I have suddenly only climbed 350m. Not fussed about the swapping from feet to metres, I want to know where all my climbing has gone too. It steals lots of feet from me.
I wonder if one is measuring elevation changes ie a drop of 300 feet followed by a 300 feet climb is 600 feet whereas the other is just measuring climbs? I'm just guessing though.
T.M.H.N.E.T
Northern Ireland
My 800 has never lasted more than 8 hours on full mapping, turn by turn mode.
Never had the nerve to run it dry and carry an external charger (10 minutes at a tea stop) for rides over 8hours.
J
Thats because, keeping a garmin on it's mapscreen by default kills battery life. It has to continually process and display map data/map points and user location when you do that.
Dogtrousers
Lefty tighty. Get it righty.
Amount of climb is one of those mysterious things ... My Garmin will give me a total climb associated with the trip, then a different one associated with the saved gpx track, then ridewithgps will give me yet another value when I upload it.
Just choose the one you like best. Ifyou don't like any of them, just make something up.
PK99
SW19
more likely the Unit is using its internal barometer and Connect is using mapping data.
Connect and ride with gps use differnt mapping and give different results!
martint235
Dog on a bike
Welling
So to do a long ride in an unfamiliar place I'll be fine so long as I turn off the most useful feature?
My smartphone battery will last a week if I turn off the screen and the mobile signal
zacklaws
Beverley
I can just get around 12 hours out of my 800 and that is with navigating a route. Ensure the backlight is set to a low setting or off completely in the daytime along with the shortest time for it to be on and do not have the map constantly displayed. There is absolutely no need to have the map displayed, the only time you need to look at it is if you think a turning may be coming up etc or a quick glance to confirm you are on route in which case open up the map. Follow bread crumb trails, GPX file. Don't bother with TBT navigation, it is too unreliable that it does not always open up the map page when you come to a turning and its also using battery power. There is no need for those pop ups which tell you which way to turn, just look at the bread crumb trail and follow that. Nothing more is needed for navigation. Turning tones off also saves battery power.
On my Dakota 20 I can get almost 24 hours sometimes, by riding with it in sleep mode for long periods of time in map mode, if I'm on route and I am approaching a junction and I might have to turn, I touch the screen, it opens up the map page for 10 secs, I can see if I have to turn and then it goes back to sleep again.
jonny jeez
To be fair, I can switch so that the map only pops up when a turn is approaching. To be honest though I like to see the surroundings on the map and have plenty of notice if turns and features. So an external charger works fine. A ten minute top up over lunch refreshes to almost full charge and I have never got close to an empty battery, even with full maps and back light showing (night ride)
