stelencro
- Alford Lincolnshire
trying to load an os map into my garmin 1000 using a preloaded sd card bought from Amazon. it does not recognise it. I thought you just put it into your garmin and that was all you had to do
I am trying very hard to resist the temptation to buy a Wahoo, and you aren't helping ;-)Sorry but you need to buy a Wahoo.
I couldnt resist.
Care to elaborate please? My bold, by the way.Overall I think I prefer the 1000 over the wahoo elemnt.
The 1000 does have a few bugs in it, but the Wahoo isn't without issues either.
I have an 810 and its very temperamental. When its good, its very very good, when its bad, its horrid!Dont resist. My Garmin Touring has not been out since I bought my Wahoo Bolt. I use it every day and cannot make it go wrong. I havd just downloaded a 200km route into it in less than 10 seconds. Apart from the Etrex range. Garmin is in the dark ages compared to Wahoo.
thanks for the info. do you know how up to date they are?you have to go into maps in the settings and select the map you wish to use
should sort it for you
think the map you have may have a date on itthanks for the info. do you know how up to date they are?
I don't like how it doesn't guide you back to a route you are following if you miss a turn like it does on the garmin.
Garmin gives more detail on the screen for distance, temperature etc
I’d like to be clear about this to be sure I’ve understood you.
When using my Garmin 810 if I miss a turn the device will reroute or advise a U turn. Also, if like yesterday, I make an error in my route plan and ignore the directions when I get back on route the Garmin acknowledges this.
I’ve obviously read what you posted but just to be 100% the Wahoo range does not re route?
I’ve spent time researching these and hadn’t spotted this. If correct it seems like a very, very basic omission. A feature I would expect on any recent GPS navigation device and its abscence would wipe Wahoo off my list.
