- South Manchester
Have you done the press and hold the three buttons, then the power one reset trick ?
My claim was accepted straight away, no problems there. I just keep getting fobbed off that the cheque is on it's way but it never comes.I had a lot of problems getting the refund, but after a bunch of photos they agreed...still waiting for the cheque though.
You have to travel quite a long way to confuse a GPS - a hundred miles or so. It remembers where it was when it was switched off, so it has a 'head start' in finding the satellite signals next time it is switched on.Iv reset it now so I don't think it would make much difference if I took it back to the last place it worked....not actualy sure where that was now.
If you turn it back on at the same place you turned it off it should be quick. If you've travelled in between it takes longer to lock onto sats, apparently.
Only problem I'm having is getting my feckin' £30 cash back from Garmin![]()
No, it is due to how GPS works.Yep had same thing on my 800 - went to Spain and had put new map card in - it took ages. Same when I came home and put the UK card. Bit of a software glitch really.
