T.M.H.N.E.T
- Northern Ireland
Happy to help
I found that out by messing it up
Press the start button, same applies if you're following a course.
When you're done, press Start/Stop and press-hold reset as usual to clear all the data.
Correct; the reset button saves the activity. If you don't do this then Garmin just sees a continuous ride; hence your experience in France.Normally, on returning home following a day's ride, I download the data onto Garmin connect. However last year I toured in France meaning that I could not download the data at the end of each day. In fact, when I got home, the first four days were recorded as a single event, and the remaining days into a second event.
In order to break up this long tour into individual days, should I have pressed and held "Lap/Reset" at the end of each day? (The "reset" bit worries me that I might lose the recorded data from that day, can I interpret this as a "save" function instead?)
ta
Nice thread! I've just bought one, about to use it for the first time in... 40 mins. Excited, I love new gadgets.
I had lived the options to save to device or SD card, and wondered the following, don't know if anyone can answer...
I have the discover trails option, so have the preloaded SD card in there. If I save tracks to the SD card, will it cause any problems due to having the maps on it - and is there even much space? Also, how many tracks with the device itself hold, and if it gets full will it automatically overwrite the oldest, or do we have to clear them all out once in a while?
