Are there any that automatically upload to Endomondo or Strava, maybe via WiFi or summit similar?
depends what you want it to do, edge 200 if you just want to record rides and upload. (courses is good too). if you want to use a cadence sensor or heart rate strap you need the 500, 800 is the daddy of the range and can do everything
You still need a cadence sensor; I fitted one to my irregular shaped stays on the Bianchi and its never been a problem the zip ties hold it securely.Does anyone know if the 500/800 have some sort of built in cadence calculator ? or do you still have to fix something to the frame, when I bought the bike I tried to get a cadence comp fitted (a basic one not a garmin ) and couldnt find one that would work due to the shape of my frame (bike is a Kuota Kebel )
HLaB,thanks for that, as you can probably see I'm not very familiar with any of these computer gadgetsI currently have a very simple cateye comp !! basic but simple
the 800 doesn't have the same limitations as the 705 with regards to course points. It is smaller and the touch screen is good, whereas the 705 has a joystick which often breaks.Except Wireless communication with other devices.
The 705 does and has a sharper screen as well. In fact unless you want the touch screen and OS mapping then the 705 is the better unit!
