Garmin 200
sight-pin
I seem to be having problems today uploading from pc to the unit, instead of showing the connecting screen, it just keeps going over to the download windows screen as if i'm a first time user.
Tried downloading the new windows bit but to no avail as it still does the same. Although! earlier today i did manage to download a coarse to the unit with no problems.
The rest of the page is working ok ie showing my done routes etc.
Any ideas?
TIA
Update..I just found this if i now try to download to the device..."Garmin Communicator Plugin NOT detected" ?
L14M
HAve you installed the garmin browser plugin if not do it!
S
sight-pin
To be honest i'm not very up on this..i just followed the instructions when i first ever connected it to the pc some months back...it seem to want me to download garmin express and sync, which i done earlier
Cubist
Still wavin'
Ovver 'thill
Your browser is probably blocking the communicator plug in. Either allow it via settings, or click on " always allow" if you get that as an option/ prompt.
S
sight-pin
That seems to be the results i just had, i clicked "always allow" but still just get this >
Getting started is easy!
Download Garmin Express to sync your device with Garmin Connect.
Download for Windows
I'm Lost!!
Thanks though anyways
S
sight-pin
I've tried to sync 3 or 4 times but still get the same results
Do you think it could be a problem cropped up with the unit?
It's strange because the "dashboard etc" works fine?
Rasmus
Without a clever title
Bristol
I couldn't upload my ride tonight to Garmin connect either. Looks to me like they did some sort of upgrade to the website so it no longer works with the "old" plugin.
You might have some luck if you remove the existing plugin, and then reinstall. Or maybe you just need to wait until garmin fix a bug in the website.
For my part, since it appears they will not support linux, I will simply stop using garmin connect.
cosmicbike
Perhaps This One.....
Egham
Have you just done a Windows update as this sounds exactly like what I had when internet explorer was updated to version 10
S
sight-pin
Aha sorted! I don't know what i done but it's working ok now:thumbsup:
Cheers
S
sight-pin
Thanks for the input about them uprading the website, i was starting to think something was wrong with the 200 unit,lol
I did do the advised update Garmin was offering, I tried everything i could to get it working, Complicated stuff stuff lol
Thanks
Rasmus
Bristol
I have abandoned garmin connect. Just uploading to Strava and RWGPS now.
If newer garmin products cannot be used on linux, I guess I will need to look for a different brand if I decide on a new purchase.
Leaway2
Lycrist
I could possibly run under wine, but its a lot of faff. I don't use the Garmin in any serious way, so I will probably sack it off and just use map my ride on my phone.
