FSA crankset on Cinelli Veloce..?
Tin Pot
Hi all,
My Cinelli Experience has Veloce shifters and miche cranks and cassette. I want to add a power meter crank, but there is little support for campag.
However, I notice this Bianchi Veloce uses an Fsa Omega MegaExo Compact 50-34T crankset:
http://www.wiggle.co.uk/bianchi-impulso-veloce-2015/
So, if I buy a crankset here:
http://activesport.co/epages/80c85f...4f3f2e/Products/330-2036/SubProducts/330-2036
Then I can buy an FSA Stages:
http://www.merlincycles.com/stages-power-fsa-energy-bb30-72605.html
What is the flaw in my cunning plan..?
U
User6179
Is megaexo not a Shimano compatable 24mm spindle and your Stages Power FSA Energy BB30 is 30mm spindle!?
Tin Pot
Tin Pot
Imagine for a moment that I have no idea what you're talking about :smile:
If it fits on the Bianchi why wouldn't it fit in the Cinelli with the same shifters?
U
User6179
The crank will fit but the fsa stages is not compatible with that crank as I think one has a 24mm spindle and the other has a 30mm spindle .
Edit- If your crank is currently 24mm and the new one is 30mm then the FSA stages will fit the crank but wont fit the current BB
U
User6179
Ah - I see, so if I find a PM compatible I could be okay.
The PM says compatible with BB30 cranks , it may be compatible with 24mm ones if it tapers to the same size .
If your BB is square taper for the miche cranks you will also need a new BB.
Citius
That PM will not fit on the cranks you have linked to. A BB30 arm will not attach to a MegaExo spindle as the method of securing the arm to the spindle is not compatible. The BB30 crank arm will also have a different profile/angle anyway.
Citius
That one says it is not compatible with the crank you linked to earlier...
Tin Pot
Tin Pot
Oh bugger, shall I give up? This PM nonsense is complicated AND expensive. I can only handle one of these at a time.
