Drago
- Suburban Poshshire
Breeze Blockers. About as aesthetically pleasing as Eric Pickles in a mankini, but extremely effective. http://www.breezeblockers.com/
Now I'm never going to be able to wear the farking things without thinking of that very non farking image.Breeze Blockers. About as aesthetically pleasing as Eric Pickles in a mankini, but extremely effective. http://www.breezeblockers.com/
Sound great. Are they warm and what are they?I rarely use my thick cycling gloves. Like ski gloves and you can’t feel the bike. Hate them.
Here's a radical suggestion: put your warm layers and gloves on before you go outside, then just get your bike out, hang the bag on it, close the shed door and ride off. "Get it ready"? Is it an old Raleigh Wisp that needs refuelling or something?So, if you have to go out to a cold garage to get your bike out and get it ready. Put gloves on. Come back in and get warm.
Bring your bike into the warm while you get ready, putting on your warm layers.
Put all layers on the radiator until you are ready to go and leave your gloves and liners on the radiator until you are completely ready to set off.
Get reusable handwarmers instead of yet more single-use landfill shoot, but keep them for a heat boost as they don't last as long.Try Hot Hands stick on hand warmers.
They make them for toes as well.
Apply them to the inner gloves.
It is essential to peel the back off and leave it exposed to the air for quite a while.
That's a good idea. Winter gloves rarely dry during a cafe or lunch stop and putting wet gloves on is generally bad.Take a spare pair of gloves to change into on wet rides.
If it's an Android phone, you can set it to answer and end calls on hardware buttons, all of which can be operated with gloves on (give or take an occasional fat-fingering), and read out text messages (with the ability to shake the phone to stop it, if you think it's going to be sensitive). You can also set it to autoreply to calls with texts or punt them to voicemail.Don't take your gloves off during the ride - go inside somewhere if you need to use your phone.
Sometimes I can't resist taking a photo and I have to weigh up the beauty of the scene I want to capture against the pain of cold hands.
I attach water bottle(s), bag, lights and check tyres.Here's a radical suggestion: put your warm layers and gloves on before you go outside, then just get your bike out, hang the bag on it, close the shed door and ride off. "Get it ready"? Is it an old Raleigh Wisp that needs refuelling or something?
Do you mean the ones that you have to put in boiling water to re-set? - also uses resources unless you are using renewable energy.Get reusable handwarmers instead of yet more single-use landfill shoot, but keep them for a heat boost as they don't last as long.
If it's freezing out, the water bottle stays in the bag until I want a drink, the lights are bolted on the bike and my tyres are plain black not checked. ;-) Attaching a bag doesn't take long, although some are quicker than others - spring-handled pannier hooks (Ortleib QL something) probably quickest.I attach water bottle(s), bag, lights and check tyres.
I'm using renewable energy for that. I don't see a good reason not to.Do you mean the ones that you have to put in boiling water to re-set? - also uses resources unless you are using renewable energy.
They come in different sizes. Mine can go on the back of my hands, but I find the wind cools them too much there, so I usually put them in the palms. I don't hold the bars with my palms (unless holding the front end down over cobbles and I'd try to avoid that when it's freezing).I tried those but they are too bulky to fit inside your gloves and still be able to hold the handlbars comfotably and safely, whereas the single use ones are thin and go on the back of your hands out of the way of gripping anything.
