Yellow Saddle
- Loch side.
We are talking at cross purposes. I thought by top third you mean the top part of the stroke. You are talking about the first (TOP) part of the adjustment. Yes, your experience correlates with the way the mechanism is designed. It is basically a venturi that is closed by a screw-in dial. Although the screw thread is linear and the aperture closes linearly, the flow dynamics are not correspondingly linear. Your best way to tackle this problem is to repeat the same turn on the bike, each time adjusting the fork a little bit until you get the desired response. It is very fiddly and most people don't identify what you've noticed and just ride the fork with whatever setting it has since little Johnny last fiddled with the knob.Like I said, it didn't seem to respond in a linear way when I was adjusting it. 2 or 3 clicks into the top third of adjustment seemed to make more of a difference than in the middle. I went up and down a few times to be sure but I'm just adjusting this on feel, I could be wrong. I also read online that the lockout was not effective until the forks had been ridden a few times. I found this to be the case myself. I was on the verge of taking it back when it began working properly, so perhaps there's an element of bedding in going on.
