indigodave
I am trying to figure out what is causing my front tire to wobble at all speeds. I've eliminated the tightness of the flange so I don't know what to do now. Anyone have any tips for me?
When you check it (possibly upside down) and assuming rim brakes (not disc), as the wheel goes round, does the gap between the brake blocks and the rim vary? Edit: And sideways movement when stationary?When you check it (possibly upside down) and assuming rim brakes (not disc), as the wheel goes round, does the gap between the brake blocks and the rim vary? Edit: And sideways movement when stationary?
If it does then the wheel/rim is out of true and needs trueing or the hub is loose. If not it's the tyre not properly seated.
Have you removed and reinstalled the wheel in the fork dropouts yet?
Have you removed and refitted the tyre yet? QR lever, nuts or thru-axle?
"eliminated the tightness of the flange" not understood. How did you do this?
As above. The tyre is possibly not seated on the rim correctly, or the rim is slightly buckled, or a bit of both.
Okay well now I'm fully confused. I've had plenty of suggestions as to what it could be causing the wobble and as I alluded to in my previous posting I'm even being told that it is a result of the rear tire being out of true which is quite possible anyway because the spokes are loose and clattering as I ride. I purchased this from someone who was the original owner with a non-transferable 5-year warranty and I'm working on getting that person to proxy the bike into the repair shop so that I don't have to get hit with a massive bill right now
This thread started with the problem being in the front tyre, then moved to the headset and now it's the rear tyre (or more likely the rear wheel).Okay well now I'm fully confused. I've had plenty of suggestions as to what it could be causing the wobble and as I alluded to in my previous posting I'm even being told that it is a result of the rear tire being out of true which is quite possible anyway because the spokes are loose and clattering as I ride. I purchased this from someone who was the original owner with a non-transferable 5-year warranty and I'm working on getting that person to proxy the bike into the repair shop so that I don't have to get hit with a massive bill right now
RichardThis thread started with the problem being in the front tyre, then moved to the headset and now it's the rear tyre (or more likely the rear wheel).
