Front Pannier Racks Tour de Fer 2017
toffee
Anyone put front racks on a Tour de Fer 2017.
Just come to put some on Mrs T'S and found the front disk in the way
toffee
toffee
[QUOTE 4755667, member: 76"]Could you put some washers on the rack side so the bolt doesn't go through?[/QUOTE]
The problem is how far the calliper sticks outside of the forks.
Done a bit of thinking and think I have got a solution.
Will post back when I have done it
toffee
toffee
[QUOTE 4755735, member: 76"]Could you not use the thread at the front of the forks? That would be better for forks if the mudguards are already on the back one.[/QUOTE]
That is going to be part of the solution. Mudguard stay is actually further out than the calliper so it needs moving aswell
andrew_s
Gloucester
If you put a Tubus Tara lowrider rack on, there's only one tube at the dropout, running from top left to bottom right on your photo. The rack also has a subsidiary eyelet on the upper side of the tube to take the displaced mudguard stays without having to share a bolt. You may need a short spacer to clear the fork blade, but it should be fairly straightforward.
I used one with discs on a Singular Peregrine, but on a quick glance I don't have any photos with the area of interest unobstructed by panniers.
The other option would be an over-the-wheel rack, like a small rear.
toffee
toffee
The problem is that the calliper will be touching the pannier, which will put a hole in the pannier eventually as it will rub when ever the brake is applied. Whichever rack is used it will need a spacer on to move the rack out of the way of the calliper. The mudguard stay is just another problem.
