astrocan
- Abingdon, Oxon
I got a good deal on a complete drive set (BB, crank, chain, cassette) but it did involve changing from a cartridge BB to Hollowtech external bearing. All fitted well but the crank is longer than the old set up and now the front mech won't reach the outer ring.
The installation instructions for the BB indicated that I should fit one spacer on the left and two on the right. Has anyone tried putting two on the left and one on the right to bring the whole thing across 2.5mm and would this work? Clearly the tubular spacer that sits between the two crank arms dictates the overall distance so is it possible to get a marginally shorter one, though I suspect that would leave an ankle shredding stub stcking out the left side.
The other remedy would be to fit a mech with a longer reach but I have no idea how to differentiate between options that would and wouldn't work so any advice in this direction would be very helpful.
I'm a little bit tightwad about getting a new mech partly because the current one works fine plus on my twelve year old bike I have only the frame, bars and mech left from the original so I'm a bit moist eyed about binning it while its still OK.
