summerdays
Cycling in the sun
- Bristol
I believe that for my own safety it's better NOT to blind the person driving a big lump of metal (or a bike on a bike path), in case as they look away from me to avoid the glare.
There was someone killed by blinding a car, back in the early days of HID lights.It's always struck me as a monumentally daft idea to blind the oncoming driver of a 2-tonne vehicle...
Totally agree! I think a lot of people just go down the "get the brightest lights on earth, I'm bound to be safe" route. You have to appreciate how to use those lights safely too. The brightest lights (aimed correctly) are still going to get you seen, and are probably going to do infinitely more for your safety than momentarily blinding the driver of that great hunk of metal heading straight in your direction.It's always struck me as a monumentally daft idea to blind the oncoming driver of a 2-tonne vehicle...
£64 for the light alone https://www.evanscycles.com/hope-vision-1-led-front-light-EV181070
Or £76 with batteries and a charger.
so yea.... I use (and will always use) very bright bike lights![]()
How did you know what kind of light it was, if you were blinded?I hate those bloody things. I'm sure they're a fine light, but having been blinded by several that were either poorly adjusted, or encountered when the owning rider/bike was at the wrong angle, I developed a distinct dislike for them. Especially on flashing mode.
It was at the height of their popularity (particularly, god help us, mounted in pairs) and there was little else available that was similar. (Pre the influx of cheap crees &c)How did you know what kind of light it was, if you were blinded?![]()
True, although it's less likely with a shaped beam. (Mounting it intuitively (i.e. more or less "flat") results in the light going, for the most part, on to the road, whereas the round beamed lights will spill more).I imagine the "blinding" issue is common to all handlebar mounted lights where you can swivel the light up and down, even those with shaped beams like the Ixxon (sp?) can probably be positioned to do so. The Hope isn't an especially bright light, I don't think.
Just a note on the chinese ebay lights, mostly the light units themselves are actually quite good but let down by pretty dodgy battery packs. I've never had one explode on me, nor have I had a light quit either. The battery longevity is where they fail and the claimed lumen output. They will be bright but "chinese lumens" tend to be about half the official ANSI rating so if it's quoted as 1500 lumens, you're probably getting 600-800 ish, more than enough for most people's needs.
The answer is to buy a dedicated battery charger and some quality batteries then fit them in a unit like this.
http://www.ebay.co.uk/itm/Waterproo...697909?hash=item2369f7b975:g:yOYAAOSwNSxVNh9w
And by the time you sort all of that out you could have probably bought a branded light as mentioned elsewhere. Sometimes it's just a false economy buy cheap buy twice ! Of course you may just get lucky !Just a note on the chinese ebay lights, mostly the light units themselves are actually quite good but let down by pretty dodgy battery packs. I've never had one explode on me, nor have I had a light quit either. The battery longevity is where they fail and the claimed lumen output. They will be bright but "chinese lumens" tend to be about half the official ANSI rating so if it's quoted as 1500 lumens, you're probably getting 600-800 ish, more than enough for most people's needs.
Anyone got any news on a possible new version of the vision 1?The Hope is great run at the lower settings on road.
