Front Disc brake noisy
glasgowcyclist
Charming but somewhat feckless
Scotland
Are your front and rear discs interchangeable? If so, swap them round (giving the current front one a good clean first) and see if the noise moves to the rear or stays at the front. If it stays at the front then I’d suspect a tiny leak from the caliper.
I know you’ve found no evidence of a leak but I had the same persistent problem appear suddenly and nothing fixed it until I replaced the front caliper.
Cycleops
Accra, Ghana
Looks like the only solution left is a new caliper although you might try Glasgow's suggestion first.
fraz101
fraz101
I put it all back together this morning.
I did notice that the disc was rubbing slightly to one side on rotation.
I’ve fixed that.
I will bed the new pads in properly and re test
