Bigbud
- Manchester
The front derailleur seized up the other day and I went to fix it today, seems I was a bit heavy handed and I've rounded a thread and its knackered
Took it into evans and they say its shot.
The original was a Tiagra but the guy in the shop says that the new ones won't fit as mine is a 34.9 Dia, the only one I can find thats is a 9 speed double and is 34.9 Dia is the Sora which seems silly too step down
So any suggestions please ??
34.9 DIA
9 Speed
Double front (Although the shifter does shift three times)
Also the rear brake has gone as well so was going to get a tigra to replace it (its a cheapo nasty one at the mo) But have seen these
http://www.wiggle.co.uk/miche-performance-57mm-drop-brake-calliper-set/
Its only for my commuter and my ride in is fairly flat so thought they would be ok, anyone used them ?
Thanks
Jim
34.9 DIA
9 Speed
Thanks
Jim
