doffcocker
Hi all.
Please forgive the incredible naivety in anything I write in the following post. I am extremely new to cycling - yes very much part of the Covid-inspired wave of riders - I didn't actually know how to ride a bike pre-2020 and I'm 28 years old, but since March I have been averaging 10-30 miles daily and whenever my bike isn't up to its optimal, I feel extremely depressed and lost so would appreciate any friendly advice.
Basically I have an issue with my front derailleur, or more specifically the lever and barrel adjuster. To add insult to injury, the problem is one of my own making.
It all started yesterday when I decided to finally try and get rid of the irritating grinding noise of my chain when in the highest gear/smallest ring. I had heard somewhere this was easily resolved by adjusting the limit screws of the front derailleur, and in my infinite stupidity I got tampering without first checking exactly what I was supposed to be doing.
Before I knew it, the front gears weren't for shifting up to the larger ring, so that's when I got carried away messing with the barrel adjuster until finally it seemed the lever had lost any grip at all on the cable. I have tried to tighten the slack at the derailleur but this hasn't made any difference to anything.
Now I don't often move into the larger ring of the front gears anyway so until I decide to fix this, it would be alright except that somewhere in the midst of all this drama, the grinding noise that was once only apparent in the highest (8th) gear is now very audible from the 4th/5th gear upwards. Again I have done much trial and error with the limit screws to at least resolve this but nothing seems to be making a difference.
I'm guessing that at the very least the cable needs to be re-seated correctly within the lever mechanism for the front derailleur to operate correctly again, but also what else could be causing the grinding noise considering I feel like I've tried every possible combination with my front derailleur limit screws. I should also add that the rear derailleur currently operates fine in terms of shifting from one ring to the next.
Thanks again in advance for any advice whatsoever whether in the form of words or links or whatever.
Cheers.
Cheers.
to the forum.
