Omar Ghalayini
Member
- Lebanon
Hello y'all
I hope you're staying safe during this pandemic.
I am building a customized bicycle. I've ordered a carbon fiber mtb frame from Aliexpress (probably not the best option out there...). I also purchased a Shimano Alivio Gearset (also used for mtb bikes).
Long story short, the front derailleur doesn't slide further down the frame (check picture).
I need to get it down or else I won't be able to use except the largest gear. The front sprocket is too far off the front derailleur. You can see from the attached pictures that the frame becomes wider near the bottom and hence resists the derailleur from sliding further.
I've been trying so hard to fix the problem but things didn't go well. I also messaged the seller but didn't give me a clear answer. As if they don't know!
I also tried adjusting the range of the front derailleur through the 2 screws but it also didn't work. It's far off the front sprocket!
I got to think:
1) Are there special gearsets designed for such frames that become wide at the bottom? If yes, what are these gearsets?
2) Is there a certain accessory that would mount on the frame, and in return, the front derailleur will mount on it? (For the sake of sending the derailleur downwards)
Please any comment will help. Thank you!
I got to think:
