MickeyBlueEyes
Eat, Sleep, Ride, Repeat.
- Derbyshire
I'm having trouble, and by that I mean its driving me feckin' crazy, trying to get the chain to move from front inner to front outer. It happened Sunday morning without warning, it was fine putting the bike away Friday evening. I've tried everything I can think of, to the point where it's either something stupid I've missed or my latest assumption that the lifting pegs are worn too much to make any contribution. I'd love to hear about any issues anyone and everyone has ever had with the same issue so I can go through and tick them off when I've tried them.
Some facts:
Chainrings are Ultegra 6600 SL 50/34.
Derailleur is Ultegra 6600 as are the shifters.
Last night I managed to snap the screw that holds the cable so I took dérailleur off to drill it out which was successful. Whilst off the bike I checked the travel of the derailleur by going to inner and then outer extremes with the limit screws. Derailleur moves smooth and as it should.
I have tried two cables to rule this out. Both functioned exactly the same as the other.
Imagine being on the inner chainring, moving the shifter to shift up and the shifter stops when the chain is just about to engage on the pins. What I do know is that the movement of the derailleur in this position is not being stopped by the limit screw as I have exaggerated this to the point I should see the chain ditch over the top.
There's a couple of things nagging me, have I got the cable tension wrong and this is what is stopping it, or, has the outer ring come to the end of its life. It's probably seen the best part of 20'000 miles so I wouldn't be surprised. I would like to explore every mechanical option first though before shelling out £68 on a replacement.
Cheers folks!
Some facts:
Cheers folks!
