derrick
- On the edge of London
Where would you put them.And for trikes, you can have two front brakes
Tut tut.
Regulations aside... having two working brakes is common sense. If one fails you've got the otherI was going to invoke the wrath of the 'law' but then couldn't find the relevant regulation which (may or may not) require two brakes. ...
^^This^^Or just learn how to apply brakes.
And if all brakes fail, you've got shoes...Regulations aside... having two working brakes is common sense. If one fails you've got the other
I did this with both wheels. I got a lift to the start of a ride. Assembled my bike, set off towards the start but saw a friend sitting on a wall. I put my brakes on. Nothing (well ... not much) I waved as I sailed past but fortunately wasn't going very fast and managed to turn the bike up hill to stop.Have you ever pulled a wheel and forgot to return the brake release to the tight position and discovered this when going downhill at 30 mph?
I always test both brakes within about 20m of pushing off. No-one could trust my schoolmates not to have been sabotaging bikes in the shed and it's a good habit to have.I did this with both wheels. I got a lift to the start of a ride. Assembled my bike, set off towards the start but saw a friend sitting on a wall. I put my brakes on. Nothing (well ... not much) I waved as I sailed past but fortunately wasn't going very fast and managed to turn the bike up hill to stop.
Honda had/have a linked braking system too; I have it on my 2002 VFR 800. Front brake lever operates 2 out of the 3 pistons on each caliper of the front brake, as well as 1 of the 3 pistons on the rear. Rear brake pedal operates 2 of the 3 pistons on the rear brake, plus 1 of the 3 on each of the front calipers.Moto Guzzi had a linked system where the pedal brake operated both the rear brake and 1 of the front discs with the hand lever operating the other front disc.
Not much chance of an 'endo' on that.
I'd normally agree with you but after the 55mile club run on wet/mucky roads my front rim was mockit and my rear rim was relatively clean. I knew I was starting to favour the front break butFront rim always stays cleaner than the rear so in wet weather I use mostly the front brake to avoid wearing out my rear rim.
