MonsterEnergy
When i hold down my front brake, it makes a horrible squealing noise
Anyone know why this is, and how to fix this.
Well, i do actually have disk brakesDepends on the type of brake.
If disc, I've no idea. Mine does in the wet and sounds like a tortured banshee.
If cantilever, V-brake or caliper, you could try setting the brake pads so that they are 'toe in'. This basically means that the front of the pad hits the rim slightly before the back of the pad. About 1/2 mm should be enough. There will be instructional videos on YouTube if you're not sure how to go about doing this.
Great all-weather low-maintenance brakes, discs, aren't they?Start by cleaning everything with brake cleaner then clean the disks with fine wire wool and rub the face of the brake pads with very fine wet and dry.
Amongst the people I ride with the general view is discs squeal for two reasons:When i hold down my front brake, it makes a horrible squealing noise
Great all-weather low-maintenance brakes, discs, aren't they?![]()
Its mainly when im in a Low GearAmongst the people I ride with the general view is discs squeal for two reasons:
New pads taking a while to settle in, especially in the wet.
Cheap pads
Most people I know find it settles down after a few miles.
I'm afraid I can't think of any reason why the gear you're using would influence the noise from your discs.Its mainly when im in a Low Gear
Can I ask how and why. I'm on a road bike but the only maintenance mine require is new pads. Could the terrain you ride on an MTB be an influence?I seem to spend more time and money on my MTB hydraulic disc brakes, that I do the rim brakes on my road bike.
Hub brakes are the way to go. Or stop, rather.To be fair rim brakes can squeal just as much and usually for similar reasons.
