- South Manchester
Needs to come out. Pop the bolt back on and tighten up a good few times (so thee is plenty of thread engaged), then tap the bolt with a hammer.
after last night, if he wants hitting with a hammer I will more than happily do so! (he snores and last night was a very bad night!)With the wheel out, gently rest the bottom of the forks on a block of wood. Then straddle the bike, grab the brake blocks and try to wiggle the caliper from side to side. From this position you should be able to use a bit more weight and you might just break the corrosion that is binding the bolt to the fork. (and don't let hubby catch you trying this - he might get the wrong idea)
Ok - I think he has broken it... there is now a line of paint chips around the top of one of the struts (?) and all of the chips join together. All of them have come off 'of their own accord' rather than him missing with the hammer. It is not filling me with confidence!
I think I might be needing a new bike - probably cheaper than new carbon forks & brake calipers!
This is getting silly.
Penetrating oil won't make any difference; you've got to break the bond that has formed where the aluminium oxide from the fork has expanded and filled the already tight gap around that long pivot bolt. A good way to do it would be to find something like a steel rod that fits snugly down the hole from behind, press it up against the end of the stuck bolt and give it a very hefty whack with a big hammer. However that could slip sideways and peen over the end of the bolt (i.e. flatten it) so it would probably be easier to refit the cylindrical nut then unscrew it by two or three turns, than whack that. That will protect the screw threads on the brake pivot bolt. Once that has broken the bond, remove the nut and carry on with option 1 but using gentler force or a softer-faced mallet on the pushing tool. This operation would be easier if you removed the entire fork from the bike and laid it flat, face down on two solid blocks on a hard surface with the brake caliper free.
Applying lots of force to the cylindrical nut might damage it by also peening over the edges of the hole where the hex key fits. This is no disaster as every bike bodger and bike shop will have a spare one floating around in their box of bits. These bolts are usually hard steel but Btwin parts do tend to be made from Brie or Camembert.
Stop wasting time with oil and give it a hefty whack. It will come out. Before replacing it, clean everything up and as somebody else wrote above, coat everything in grease because the pivot bolt is terribly exposed to water from the front wheel.
Why do people persist in believing that penetrating oil can free rusted or siezed fittings? It can't. It only works once the bond is broken and parts are moving.
