My lady has moved from Hythe in Kent to Ashford. She has built-in freeview which worked fine at her old address but doesn't in central Ashford. A quick check on the freeview website says that the signal comes from the Heathfield transmitter and is not available to her new address. Further, it still won't be available after the digital switch in 2012. Progress eh? Are Sky or Virgin Media the only viable options?
Bill
What does doesn't work mean? Did she retune? Is the picture stability not so good? Whole muxes missing? Is the rooftop aerial and cabling decent nick?
http://www.wolfbane....gi-bin/tvd.exe? tells you many more details.
I would be careful about virgin media as it won't be available in all addresses. You've probably checked this though.
I picked a postcode in central Ashford and put in TN23 1QN into wolfbane and it came up with the following
Dover B only mux 1,2,C field strength
35 dBµV/m 17 miles away amplified extra hi gain available
Dover all muxes on fairly low power
31 * dBµV/m 17miles away amplified extra hi gain available
Bluebell Hill all muxes on fairly low power 31*
dBµV/m 19 miles away amplified extra hi gain available
I would say that based on the wolfbane readings, it's certainly a bit on the iffy side before switchover but shouldn't be impossible to get working.
