Frame repairable or not?
Welshnwobbly
Newport
The eyelets to sit the wheel at the rear of my Specialised bike is currently broken.
The metal insert has come away from the frame so it is not possible to sit a wheel in properly. It can be forced back in but will not stay there.
Can this be welded firm again by a welder or can you glue it or is it actually a broken frame?
Failure in the dropouts are usually terminal in my experience or are you talking about the derailleur hanger here? What do you mean by insert?
Show us what's fell off - is it the mech hanger (the silver bit)? You can get spares if that's the case as they are usually bolted on.
What's the bike.
Ian H
Ancient randonneur
If the hanger is bent or broken it can be replaced. There are 100s of different kinds, so you'd have to do some research to find the right one.
si_c
Wirral
Looks like the hanger.
Should be replaceable as has been mentioned above. What model/year of bike is it?
Cycleops
Accra, Ghana
How is the hanger attctched to the frame?
Looking closer the hanger forms part of the dropout. Are you saying it won't stay in place?
raleighnut
Has the Hanger retaining bolt fallen out ?
Welshnwobbly
Welshnwobbly
Newport
Hi,
Thanks for your reply.
It's the derailleur hanger which has come loose from the frame. I imagine it could be welded solid onto the frame?
Welshnwobbly
Welshnwobbly
Newport
Hi
thanks for your reply.
Exactly. It won't stay in place so the derailleur which screws into it comes is hanging crooked.
Welshnwobbly
Welshnwobbly
Newport
Hi
No, the bold seems to be there but at the piece where it synchs with the frame it has come loose.
It needs to be welded to the frame, I would say.
Buying a new one seems unnecessary as there is nothing wrong with it.
I think I need a welder?
Welshnwobbly
Welshnwobbly
Newport
If the bolt fell off then it would come off altogether, I think.
Basically the one bolt is still there but the weight of the derailleur has forced it off the frame at the back.
You can see it in my photo. There's a gap and it needs to be completely glued or welded solid.
raleighnut
Take it to a bike shop, the hanger is designed to come off to be replaced. If you weld it you'll wreck the frame.
