The method I adopted on the Brompton was to use a piece of threaded rod with some 15mm thick 10ID x 30mmOD plates . One pair was bolted up tight around the DS dropout, the other pair were free to slide on the threaded bar but were screwed togehter by an 8mm allen screw that went through in the slot on the NDS. The triangle was held in a vice at the chainstay bridge and the dropouts spread by screwing a nut along the threaded bar into the sliding set of plates. Both sides seemed to move equally, there was about 20mm of spring-back in the system so to achieve 130mm OLN I had to spread to 150mm and then release it back. Due to the flexing of the threaded bar the dropouts didn't stay quite parallel, but it was very easy to bend them back into line again.
