summerdays
Cycling in the sun
- Bristol
My disk brakes I have to admit are not necessarily the quietest in the world ... but yesterday I was experiencing a lot of frame vibrations with using the rear brake (Juicy 3's), but as I was really wet I didn't investigate. I noticed today its still quite bad. I can get the whole frame to judder if I pull on the rear brake and push the bike forwards even gently, whereas the reverse with the front brake just causes the wheel to lock and slide along the ground.
Other possible contributory factors ... I fell off - low speed on muddy road last week, and I had a new rear tyre about a month ago.
I've had a quick look ... I assume something has to be loose or broken to produce those vibrations ... is there anything I should look for ... though I'm tempted to just go to the LBS later this morning (but I would need to clean the bike first ).
