I have already read some articles on fitting. They are all very knowledgable and everything but they tend to fit a bike to you (crank length, seat height, seat position, handlebar width, ...). They all say that reach and stack and some angles are important, but they don't say exactly in which way they are important.
Looks like I should go for a shorter reach, bigger seat tube angle, probably smaller head tube angle, and maybe a shorter stem? Good luck to me. Thanks again for all the ideas.
Regarding your first point; that's why I like the Peter White article as it talks more about comfort in an understandable way.
Regarding the second point, I think you may want a less steep seat-tube angle. To take the weight of your hands your upper body needs to be counterbalanced. If you consider that your feet position is fixed by the cranks, your backside is then the counterbalance to your torso and arms. Stand upright and sideways up against a door frame, us you bend forward of the door frame (without moving your feet) then your backside has to move in the opposite direction beyond the door frame. It should be like this on a bike if you fit for comfort. You should be in such a position that you can pretty much take your arm off the bars and maintain body position.
I have short legs and a long back and had a frame custom made by Rourke, however they misunderstood (or didn't heed) my initial requirement which was to have a really laid back seat-tube so the seat would sit back further than normal to counterbalance my longer torso. So they did the bike fit and designed how they wanted (based on years of professional experience) rather than how I wanted it.
The bike was great, but wrong, I could see as soon as I set eyes upon it. They had used their standard seat-post angle and TT lengths based on their fit data. Being good sorts they let me take it away and run it a while just to be sure (and I was).
So I went back with the bike and a seat post on a broom handle to show them the angle I wanted the seat-post and Brian Rourke himself came along to make sure all was in order. To be fair we had a pretty robust debate about the fit and my requirements and it wasn't until Brian got aboard his own bike with hands on the hoods and then just took his hands off the hoods by a cm and remained planted in the seat .... BINGO! I did the same thing on the bike they made and I fell forward off the seat, we then understood each other. I needed the seat further back than 'standard' so a very laid back seat-tube angle. I got out the seatpost on a broom handle, we measured the angle and figured-out where to insert the extra 4cm of top-tube (2 at the satpost end and 2 at the heat-tube end)!! They scratched their heads and said they'd build it for free as long as their was no come back. Fair enough. It fits perfectly, to the mm. To the untrained eye it looks pretty normal.
From this:
To this:
To get the longer reach with the same stem length, the seat-tube has gone back 2cm where it joins the top-tube and the head-tube has gone forward 2cm where it joins the top-tube. So I have the long reach I need BUT I'm sitting 2cm further behind my feet (the bottom bracket) to remain balanced. I can take my hands off the hoods and not slip forward, meaning on a long ride I don't have a lot of pressure on my arms and hands!
OK, long story BUT, in your particular case, you need to have a bike set-up where you can get that comfortable position with your amount of flexibility and reach. A good shop should be prepared to do a basic fitting exercise before you test-ride.
