jay clock
Massive member
- Hampshire UK
If you are 5'8" and on a 55cm road bike I would be surprised if a 58cm would fit you well
You do need a bigger frame (longer TT) on a flat bar bike as the bars are further away. My roadbike was fine with drop bars, but much too small once converted to flats, even with 3cm more stem! It now belongs to a friend 4" shorter than meIf you are 5'8" and on a 55cm road bike I would be surprised if a 58cm would fit you well
Indeed, confusingok, had not spotted flat bars. I think the OP is a little confused as he keeps mentioning 18" even though the order makes no mention of that
If it's your foot contacting the front wheel during a turn, then you need to look at the wheelbase of the bike in question; the longer the wheelbase, the less likely your foot will overlap the front wheel. This tends to be more of an issue with racing style bikes than tourers or MTBs. I have a minor overlap issue with my 23" frame audax bike and that's the biggest frame bike I have - !When the pedal crank position is forward, the first few inches of my foot (the bit that is not actually on the pedal) is at the side of the wheel If I am turning at that point, the tyre makes cotact with my foot. This is why I feel that maybe a 20 inch frame would be more suitable if I buy the same model again. (I am 5'8" and my arms are quire long).
Yes if you are overstretched. I had a bike that was too big, contributed to chronic tennis elbow that eventually needed two operations to resolve!!So if I really like my bike, and I want to buy another, do I buy the SAME size or go up from 55cm to 57cm? If a bit larger frame is not going to improve the toe overlap issue then I may as well get another 55cm.
Also, could I make the situation of the fit worse with a 57cm?
You can compare the geometry charts on the website, look there at the bike you are buying, you may need to scroll or click on a tab or twoVickster-I would compare if I çould but they are ordered online.
What do you mean by "overstretched"? I am missing something here as I can only see being over stretched would apply if bike was too small ie stetching to reach handle bars. Obviously you don't mean that.
