Ajax Bay
- East Devon
If you wish to retain the steady handling characteristics for which the Surly LHT has a well-earned reputation, you need to try to find a fork with the same offset (some call this rake), that is: the perpendicular distance between the centre of the fork dropouts (before they were bent) and a (virtual) line drawn down the centre of the steerer tube. The shape of the fork blades doesn't matter (ie curved or straight) but its geometry will. If you choose a fork with a shorter offset, the handling will be more twitchy - fine for a racing bike but inappropriate for a touring bike, with or without a load. A longer offset will make the bike ride too steadily (tandem's have a long offset).Question is how much would it change the ride of the bike by putting on a set of straight forks as opposed to curved ones that are on the bike? Best I can tell straight forks would shorten the wheelbase a cm or so.
What is "longer" and what is "short"? Riding a Surly LHT, one doesn't want manoeuvrability, one wants steadiness, imo.they used to think that longer fork trail was better for front end loading. This has been disputed in later years, and many people use short trail forks for touring now. It makes the bike more maneuverable, that's for sure
See my post from a while ago for more: https://www.cyclechat.net/threads/matching-fork-to-frame.205301/#post-4464435
