Does anyone actually buy spd cleats? I find that the cleats outlast the pedals, so often have spare cleats, which in the past I've posted out to other forum members & sure I've seen other folk do the sameI know I have at least one pair of cleats in my 'spares' if anyone does need some
I must done OK as I am on with 3rd set of cleats with the same set of pedals.Does anyone actually buy spd cleats? I find that the cleats outlast the pedals, so often have spare cleats, which in the past I've posted out to other forum members & sure I've seen other folk do the sameI know I have at least one pair of cleats in my 'spares' if anyone does need some
Which bit of the shop was it in, please? I suspect ours is too small but it would be nice to double-check.Unlike many similarly priced bullet style cams though, these things have removable batteries and so can be swapped out when they go flat and can also run from an external usb fed battery or if you'e a fancy pants like me, off the dyno hub
A correction on my earlier post though is that there is indeed a helmet mount with this cam. Oops.![]()
I had to cut round it with a DIY knife - one did lift at its heel end but the other seemed to be stuck fast. Once cut round I found they came off best by pushing a non sharp knife under from the toe end. NB Shimano Cleats £7.19 from Halfords with British Cycling Discount
I bought some to use on flats, and I noticed the backing plate was in a bag with some spare laces, so they are not holding the rubber in place by default.so the shoes actually do have the 2 bolt holes underneath? Mine arrived last week but assumed that they just had permanent blanking plates moulded to the sole.
And the depth of the bolt fixings is deep enough to enable you to walk with cleats fitted without clunking on the pavement. Slight scuff marks to the toe end of the cleats after walking 2 and half miles in them - not a deliberate act, I was taking the road bike to LBS for a service (it has SPD pedals on it) and on getting it out of the shed found the rear brakes jammed onso the shoes actually do have the 2 bolt holes underneath? Mine arrived last week but assumed that they just had permanent blanking plates moulded to the sole.
And the depth of the bolt fixings is deep enough to enable you to walk with cleats fitted without clunking on the pavement. Slight scuff marks to the toe end of the cleats after walking 2 and half miles in them - not a deliberate act, I was taking the road bike to LBS for a service (it has SPD pedals on it) and on getting it out of the shed found the rear brakes jammed onso ended up walking both ways.
Showing as £19.95 just now.
I'm lucky if an SPD-SL outlasts an inner tube.My cleats not only outlast the pedals, but my shoes also.
