Found a Bargain? Do Tell.
Fair to assume it's pretty much the same as GT85?
I'm not to sure about that.
From what I've read it depends on what you want, there is a trade off between protecting the chain and gears and performance. Lighter lubes do better for performance and the heavier lubes do better for wear and tear.
I clean down my chain with something like WD-40 (which is a solvent) and an old towel then lube it with a silicon spray for racing. My work bike gets oiled out of a can of castrol gtx or whatever is around and then topped up with GT85 or may be this stuff, I've not used it before. I posted it for others who do use it and want it cheap.
Also at Halfords, 3 for 2 on hydration tablets and powers.
So, 3 tubes of High5 Zero for just £6.96 (less another 69p if you're a BC member) :okay:
And even better, the offer includes SiS Go Hydro Cola + Caffeine, reduced from £6.99 to £3.95 a tube, or 3 tubes for just £7.90 (less another 10% for BC members)
Despite showing as available, these and the Muc-off spray gives the message "Unfortunately we have not been able to reserve the items you requested" on any of the local stores I tried
NorthernDave
Never used Über Member
Yip, I'm getting the same message with all my local stores too.
That happens at Halfords sometimes - either as they've genuinely got no stock at those stores, or if there is a lot of demand it will say out of stock, but then later it will allow the order (they did this when those Sigma cycle computers appeared on their website for a fiver). Worth trying again in an hour or two?
Sixmile
N Ireland
Tried again there, order complete!
Thanks!
Thanks. Tried again now and it went through
Adam4868
