The Backlight seems to drain the battery very quickly i found i doubled my battery time by dimming the backlightI used mine last year for 6 days and although I charged it every night the battery was still about half full after each days ride. I found if you're playing with it all day then the battery runs down very quickly but if left alone it is more than sufficient.
I`m with you those tubes would be fine
I've run slightly out of size tubes plenty of times without issue, I know my 37c tyres on the CX bike has tubes rated up to 32c currentlyThen why do Michelin sell exactly the same tubes in 18-25mm width?
I've run slightly out of size tubes plenty of times without issue, I know my 37c tyres on the CX bike has tubes rated up to 32c currently![]()
I imagine it's not ideal to run the smaller ones, maybe if they were pumped up too far they could become problematic?Yeah get that, but why would michelin sell another inner that has the same min mm but a different max mm with a difference of just 2mm? Just seems v odd if they do the same job.
Man maths!Well, I don't "need" 60m but between my tricycle with 4 brakes, the tandem and a few "normal" bikes it doesn't hurt having it around.
Since you mention it I read this when I purchased it and dimmed it before I ever used it so spot on, good tip.The Backlight seems to drain the battery very quickly i found i doubled my battery time by dimming the backlight
Rapha's sale started today
Best reduction -Club Jersey reduced from £100 to £60
http://www.rapha.cc/gb/en/shop/club-jersey/product/CBJ08
