Found a Bargain? Do Tell.
stu1903
Scotland
Mine arrived today and were also Large. Fit ok tho. ^_^
Sheffield_Tiger
wow that looks cheap. I was looking at getting a Magishine. How does this compare
I've just had it out on Monsal Trail through the unlit tunnels in the dark.
Illumination-wise, this is the same as my Magicshine. The smaller battery pack does have an obvious effect - that being the battery life which is slightly less - though I have only charged it once since I bought it, commuted every day and done a 2hr Critical Mass - there was still just enough power tonight to do a 20 mile trip on half-power (full power for about half way)
Scilly Suffolk
Legs warmers are stretched so much that it looks like I've gone a bit Rocky Horror; arm warmers not so bad, but a bit short.
However, the leg warmers are a good fit on my arms.
If anyone wants the arm warmers, just send me a stamped, addressed envelope: "start a conversation", or send me a PM as we used to say, for my address.
Barbelier
Same problem with the leg warmers - large size but in danger of cutting off the circulation!
However, one pair has gone to my 11 year old son and the wife can have the other,so not a problem.
Noodley
Not a bargain as such, rather buying advice to get additional discount...ProBikeKit have a tendency to stick in a discount code with orders, giving discount on another order within x days.
I took advantage of this again this week, and got another 10% off - I ordered one item and then placed another order getting 10% off other stuff.
Arjimlad
Tights of Cydonia
South Glos
Aldi are selling motorbike gear today,
Of interest to cyclists is a heavy duty chain & padlock for £10. I have just hefted one in the shop and it was a solid affair.
dodgy
Arm warmers are great! Of course they're no good for a commute! But if you ride a lot in spring and autumn, when it can be a bit parky early on but warm up massively later on, they are indespensible. In spring, you can set out at say 7am in 3C, it might hit 15C at lunchtime, so you can just roll them off again.
potsy
Rambler
My Armchair
I got a set of the arm/leg warmers, they fit OK.
Mine will be used more on all day rides and also on the commutes, with the times I set off and go home the temperature can vary quite a bit so it's good to have some packable options.
Tomba
Unfortunately I am rather large! 6'4" and 17st. Legs like redwoods.... Sounds as though they may get on my fingers though :sad: WHats ize are they again? :smile:
They're Large, but no way they'd fit you unless you've got beanpole legs :sad:
