Found a Bargain? Do Tell.
All uphill
Still rolling along
Somerset
Spa Aubisque with 105 and Trp disc brakes now at £1050.
A great price for a steel bike.
I love mine!
Sigma Sports are having a sale of their Vel wheels, some are at half price, the examples below are around £200:
https://www.sigmasports.com/item/Vel/23-GRL-Alloy-Gravel-Disc-Wheelset/TW4Y?s=t
https://www.sigmasports.com/item/Vel/28-RL-Alloy-Tubeless-Disc-Wheelset/UPQC?s=t
I've got the 30mm version of the 28mm's above, identical apart from the slightly higher profile and found them a nice upgrade on the Mavic Aksiums originally fitted on my Ribble CGR Ti. At about 1600g they were quite a bit lighter too which is appreciated on the hills!
If you don't like LOUD hubs then I'd avoid as these are a little bit buzzy to say the least!
Sigma also have a few discounts on carbon wheels as well.
Spiderweb
Not So Special One
North Yorkshire
Continental GP5000 tyres 700c x 28mm are £34.99 plus £4.95 postage.
Members only so you will have to sign up.
Cheapest I’ve seen for the larger volume option.
https://www.sportpursuit.com/catalog/product/view/id/1634955
Milzy
I can’t believe they are saying £60 RRP when the Tubeless S version is only £20 more. Good deal if you are old school with tubes inside tires.
Why, all else being equal, should tubeless tyres be more expensive than normal clinchers?
These don't look bad for a winter bike for £595 once discounts added (S & L only) - you can add any 11 digit number to get the discount card price and then SAVE15 for another 15% off ;)
https://www.gooutdoors.co.uk/16185431/polygon-bend-r2-gravel-bike-16185431
They have 15% off all bikes so could have a 105 roadbike (rim brakes but 28mm tyres) for under £700
https://www.gooutdoors.co.uk/16507364/polygon-strattos-s5-16507364
The sizing is a bit weird though. A small bike has a 43cm seat tube with a 52cm top tube but a medium which is usually a small in other brands has a 48cm seat tube with a 56cm top tube. It’s like it was designed for short leg, long armed people.
A typical small is usually 48cm seat tube with a 53/54cm top tube.
