Deleted member 121159
Just had another thought. What do you use to plot your rides? (presuming you do that). When I plan a route in Strava it gives me an estimated time for it. Komoot does similar - and in Komoot you can set your athletic level (a scale of one to 5) - the time a route takes at a particular athletic level (which is synonymous to intensity/effort for me) is an indicator of how hard it it is. I am pretty sure that the calculations behind that are based on something similar to http://bikecalculator.com/
Though I have to admit I am not sure what you put in for "grade" - whether it is the over all gradient, or the average gradient for the uphill bits. The former figure tends to get used for outdoor rides, the latter for an online platform I have used. I prefer the latter because it gives you an idea of how steep the steep bits are.
E.g. The Applecross loop is 91 km with 1744 m elevation (according to RWGPS) = 1.9% elevation overall - so pretty lumpy. But it contains an ascent of Bealach na Ba, the climb in Britain with the most elevation in. There are websites that can tell you how much a route is uphill. I think you get my drift...
EDIT - I think I was trying to say what @Dogtrousers was alluding to - I use his rule of thumb
True, I could use the estimated time as an approximate measure of difficulty. I use Komoot and it consistently underestimates elevation so it tends not to be accurate. But still it's a measure of difficulty.
