Formula for how hard a ride is?
  • Thread starter Deleted member 121159
  • Start date
So I know that for climbs there are formulas for estimating how hard they are, like FIETS for example. Is there a similar formula to quantify how hard whole rides are?
Jameshow
Distance x elevation
Or if your in East Anglia - distance x windspeed!
ColinJ
Puzzle game procrastinator!
That kind of works, but falls down with low levels of elevation gain, and it also doesn't take into account the steepness of the climbs.
I think it should be something more like distance (km) x (1 + (average_metres_per_km_of_ascents - 5)/20). (Maybe the numbers need tweaking slightly, but the idea seems sound.)
Where average_metres_per_km_of_ascents is measured purely on the significant climbs, so trivial slopes of rolling roads don't impact the severity calculation.
That would give...
  • 75 for a (mythical?!) flat 100 km ride
  • 100 for a typical flattish 100 km ride with only 500 m of significant ascent
  • 125 for a rolling 100 km ride with 1,000 m...
  • 150 for a lumpy 100 km ride with 1,500 m...
  • 175 for a hilly 100 km ride with 2,000 m...
  • 200 for a very hilly 100 km ride with 2,500 m...
  • Some huge number for rides so mountainous that I would run away and hide from them! :laugh:
I don't think the relationship is as linear as that. E.g., 3000m of climbing over 100 miles feels reasonable but 6000m over 50 miles sounds really tough.
UphillSlowly
Making my way slowly uphill
I think you also need to take into account how fast you ride, how much effort you put in? Some people refer to this as Intensity of Intensity Factor (IF). Which can relate to headwind or whether you decide to push harder.
If you have a power meter or heart rate monitor you can measure the "Load" or TSS of a ride. These are based on formulas and aren't based on the road but on how hard you make the ride. Have never looked up the formulas though.
Once you have measured the load/TSS for a few rides you get a rough idea of how hard a particular ride will be in relation to your reference point.
Having said all that what @ColinJ suggests will pretty much give you your load/TSS but suspect it would be more accurate if you factor in "intensity"
lazybloke
Ginger biscuits and cheddar
Leafy Surrey
Yes, fatigue associated with high-intensity riding is awful. Speeds, prevailing winds, and 'aggressiveness' on climbs could all be added.
I don't want to imply Strava is an all-powerful seer, but doesn't it have such a measure already? The calculation might be documented or summarised somewhere.
Ming the Merciless
There is no mercy
Inside my skull
If rider="Ming":
Ride_hardness_index="EPIC!!"
Ride_Hardness_Index = “Merciless”
Yes I agree the actual difficulty of the ride will depend a lot on how hard one rides, but I was wondering about a simple-ish way of determining how hard a given route will be, so not taking into account the rider. What is TSS?
I'm not a Strava subscriber but it still sometimes tells me that my ride was easier/harder than or the same as usual so it must be calculating this. But this is retrospective, based on my actual heart rate and I don't know if they take wind+temperature into account as well. What I wanted to know, though, was a measure like FIETS which isn't based on rider variables but purely on the route variables, so mainly just distance and elevation.
That would give...
elevation per mile seems key but what count as significant and what don't? Why not use elevation per mile for all climbs?
UphillSlowly
TSS is Training Stress Score and a way of working out how much effort a workout is. It's used by Zwift and Training Peaks. Load is used by other programmes and seems to be interchangeable. I've found it useful to use Load to plan my training.
Formula for TSS: https://www.trainingpeaks.com/learn/articles/estimating-training-stress-score-tss/
Again is retrospective, but you can use your past history to predict how hard a ride will be. You can predict how hard workouts will be so why not routes.
Alex321
South Wales
Because it is much harder to climb 100m in half a mile (12.5%) then ride flat for half a mile than it is to climb 100m in a mile (6.6%) of continuous climb.
The Bwlch mountain climb fairly near me is a Strava cat 3, but I find it easier than several of the cat 4s round here, because while it goes on for a long way, it is almost constant at 4-5%, while several of the cat4s peak at over 20%, with sustained stretches of 12%+
For me personally, I aim for a cadence on the flat of between 80 and 95. If I can keep that up on a hill, then it really isn't a hard enough hill to count much as making the ride harder.
