Fork Installation
Tin Pot
Tin Pot
Bottom end
Black thing on first - the same way round as you have in the photo
Then the bearing - but turned over so the tapered outer edge is uppermost
First the bearing the same way round as you have it
Next is usually a thin plastic disc . It looks like its tucked up under the big black cone
Then the smaller silver ring - the same way round as you have it
Finally the big black cone
give everything a smear of grease so it'll come apart when next you need it too.
The black thing *will not* go on first. :sad:
I've struggled for thirty minutes, greased it, nothing.
The bearing goes into the fork easily.
