will do - even thought of no socks, but then worried about foot rub - the thing is, it's only my right foot which is why its confusing the hell out of me.Sure. Try all your changes with your most comfortable fitting shoes and see where that takes you. Overheating on turbo is your most likely cause of additional discomfort, as feet swell in size. It's all pointing back to sizing for me... Try really thin socks?
My foot problems were much worse in the hot summer weather...thin socks definitely neededSure. Try all your changes with your most comfortable fitting shoes and see where that takes you. Overheating on turbo is your most likely cause of additional discomfort, as feet swell in size. It's all pointing back to sizing for me... Try really thin socks?
Ergon TRP might be worth a punt not sure how good they are though http://www.chainreactioncycles.com/ergon-tp1-pedal-cleat-tool/rp-prod37987will do - even thought of no socks, but then worried about foot rub - the thing is, it's only my right foot which is why its confusing the hell out of me.
what i have just realised is the last two nights i have been using my heatgear socks, which has probably not helped - doh doh doh
yeh its the same knee/foot - the joint to the outside of my right knee, is no longer - i broke it and the peice of bone broke away so it never heeled back properly. Surgery cleaned up the area that was broken to minimise arthritis in later life, but i get no pain there at all tbh.My foot problems were much worse in the hot summer weather...thin socks definitely needed
Is it your right knee that is dodgy, if so, it could presumably be a bio mechanical wonkiness
That said my pain was mostly in the right foot and it is my left knee that is fubar'ed
Don't overdo it on those turbo sessions Jowwy; it's easy to beast yourself and leave nothing for the real thing at the weekend. Remember that the improvement in strength and fitness takes place during the rest after the beasting session. Do you use a heart rate monitor?
Did a full training session last night and had no foot issues after all the changes i made
Except the busting of my seatpost clamp the session went well
Hooray, i hope
lots of things - saddle back, saddle height changed, nose levelled, shorter stem, lowered stack, - in the end i felt less pressure on my feet during the pedal stroke, also used thinner socks, and i found out mavics have two strap positions that can be used, so used the loosest position and the tightest position and both were okWhat did you do in the end?
