Hi folks. I've been tinkering again. I came to the conclusion yesterday that my handlebars are too wide at 68cm. That's quite a bit wider than I've ever used before so I decided to cut them down a bit today. I was going to go for 62cm but found that my 31.8mm bars taper so gently that I couldn't get all the hardware in position if I went for 62cm. So I've settled on 63cm & I have to say the bike feels much better. A bigger improvement than you'd maybe expect for such a relatively small reduction in width. The steering is more accurate & less twitchy and my wrists are far more comfortable.
Still, I wonder how I could get the bar down to 62cm. It's only 10mm but I think it would then be perfect. Perhaps I can find a bar that has a more pronounced central bulge but that tapers more quickly to the ends.
