Ben Reeve
- Biggleswade, Bedfordshire, UK
The Rivendell video is awesome. Great to see the little things the pro do, like brushing on the grease rather than using your finger!!!
I started fitting the front mudguard today and hit a problem ... I attached the first Secu Clip ok but the bolt for the second Secu Clip would not tighten. Either the thread on the insert inside the fork has a stripped thread or the insert itself is loose, I couldn't tell which. (I reckon the insert is loose because the thread on the bolt didn't seem to be damaged by my attempts to tighten it.)I did get round to fitting a rack to my CAADX but never got round to fitting the mudguards. I completely forgot about this thread and did a Google search for advice just now and where did I end up ...
I must do it soon so I can use the CAADX in the coming winter rather than trashing my best bike again.
I was thinking along those lines today! I can get the bolt in, but not tight enough. I think I might put some superglue/Loctite/epoxy/etc on the thread to try and hold it in place and then add a cable tie for 'insurance'.I had one of the front secu clips attached with a cable tie when I lost the bolt. Lasted ages too. The clips hold the stays in quite tightly unless there is something caught between the mudguard and the wheel. No idea how to rectify a stripped bolt hole if that is the issue. Let us know how you get on. Gerry
Oh yes, I must watch out for that problem. I haven't checked yet. In fact, I will do it now. Hang on ...I fitted sks to the Boardman " easy on the boardman " fitting wise.
the annoying thing with guards is shoe contact turninig.
It's a spd problem as flats are more sociable with guards.
i can see now why we have posts about mishaps with these when the shoe catches the guard and then jams in the front wheel, very close to having one the other day!!
Hmm - the bike has a fairly large (58 cm) frame which means that the front wheel is further from the bottom bracket than it would be on a smaller bike. I just checked for shoe overlap and I can JUST get it to happen with my feet in the worst possible position and angled slightly toes-down. If I have my heels slightly down there is no contact with the mudguard at all.
Even when there is contact, it is minimal and the mudguard just brushes past the end of the shoe. I suppose if I did that thousands of times I would eventually wear the mudguard and/or shoe at the point of contact, but such contact is something that is likely to happen extremely rarely.
So ... Todmorden - we do not have a problem!
