- for example:![]()
We used quick releases with these, no problem.
And I continue to use QR's on those with no problem. Although as McWobble said, they are the type with internal cams.
- for example:![]()
OK - not absolutely horizontal, but horizontal when compared to vertical dropouts, and I would contend that the term is commonly used to describe the kind of forward facing dropouts shown. Are you suggesting that the only true horizontal dropouts are rear facing track ends? If so, fair enough - I must say I was confused by the depiction of the tagalong on the webpage, and took the OP's description of 'horizontal' dropouts to refer to the ones shown, and was therefore trying to answer the query in respect of those .........That is not a horizontal drop out, close but no cigar as they say. Horizontal is as they say horizontal.
So SB is incorrect? And Machinehead Software? Oh, and Vertical dropouts aren't really vertical either are they? These labels are just a useful way of identifying the various designs. Aren't they?Horizontal = track ends.
The other one = rear drop outs.
If you draw a horizontal line through those drop outs you will see that the axle will be pushing against solid metal when under pressure, for example pedaling.
- for example:![]()
My point was the semi-horizontal dropouts somebody talked about earlier were not the same nor worked the same as what we now talk about as track ends.
