GrumpyGregry
Here for rides.
Where can I get a single 75mm Allen socket head M6 bolt from?
Why you ask....
Bike has canti's. The front brake cable stop bracket is a bolt on doodad mounted on the fork crown with a bolt. The fork crown is sculpted quite heavily (steel crown carbon legs) front and rear so behind the cable stop are four washers in a little stack to ensure the stop doesn't foul the sculpting on the crown.
Ideally a similar arrangement is needed on the rear so the mudguard bracket is clear of the sculpted crown. At present the bracket isn't attached correctly and the nut isn't into the nyloc section on the bolt. Not good.
Hence need for longer bolt.
Why you ask....
