Tel said:Thanks for the advice guys.
I've done it, bloody hell it was tight. There was so much friction that the seat tube was too hot to touch! A 27.2mm came out but was only about 180mm long so there wasn't much post in the tube, my new one is 350mm so there is a fair bit extra in there, it was so tight that I considered cutting 100mm off but I persisted; in, out, in, out, each time a little looser.
montage said:simply put some metal tubing on the inside where you clamp the post.
02GF74 said:yep - I use a short length of copper pipe to stop my CF post from slipping - I had tightened the clamp to the point where I could see the varnish crack - i.e. a touch too tight.no other damage mind.
It is unlikely that the pipe will be same diameter, but you can cut a slot and file it down so the diamter is correct - the butt joint should be enough to stop the pipe from collapsing - I cannot recall if I did this or not but have done so in the past with success.
The pipe only needs to be 20 mm long and pushed to the point there the clamp is.
mickle said:Chop it to length or it'll get stuck in there.
Inserting extra material is a waste of time. It wont increase the strength of the post unless it's a very tight fit and/ or bonded in.
