Absolutely brill - love the sense of humourI am Spartacus said:Not such a strange behaviour.
When out cycling, I do get passed by many a car loaded with MTBs (usually) on the rack.
I also live in a less than salubrious part of the UK....running around is a pain..
dog shoot... pissed up teenagers... feckless unemployed ( oh feck .. that's me) ...MTBers riding on pavements ...arsey dogowners .. more arsey doggers... I can go on.. get the picture?
Thanks, will bear that in mind, I don't quite have one at hand at the moment, but will look when out shopping next.alecstilleyedye said:a bike computer will be more accurate. allow for 10% deviation with the car…
Many thanks for that info - much appreciated.fay144 said:Hi Chris, I use the gmap-pedometer or mapmyrun websites to map out routes to find distance. It's a lot quicker than driving it. And it's handy to be able to plan runs/bike rides in advance.
I was thinking about this thread when I was running up a big hill on the way into work this morning. Maybe it's because I'm a runner who is new-ish to cycling, but I am certain that there is no way I was exherting 4 or 5 times the effort of cycling up the same hill. I wouldn't even have said it was double. Cycling up steep hills really takes it out of your legs... with running you can just plod away at it. On the flat, then I can see there is a difference... 5 times still seems a lot though, to me.
Crikey, it's not that tricky, I'm only going to do it the once!dodgy said:Crikey, imagine if every cyclist mapped out their rides before hand in a car!
That's what the Internet is for!
_Chris_ said:Crikey, it's not that tricky, I'm only going to do it the once!
How would you do it on t'internet ? How accurate ?
_Chris_ said:Thanks, will bear that in mind, I don't quite have one at hand at the moment, but will look when out shopping next.
4F said:log your route on http://www.mapmyride.com and it is very accurate. Gives you an elevation profile as well
fay144 said:I was thinking about this thread when I was running up a big hill on the way into work this morning. Maybe it's because I'm a runner who is new-ish to cycling, but I am certain that there is no way I was exherting 4 or 5 times the effort of cycling up the same hill. I wouldn't even have said it was double.
Fiona N said:Hi Fay
you've sort of got the wrong end of the stick - it's the comparable distance for the same perceived effort that's a factor of 4 or 5 different. E.g. if you run hard up a steep hill at say 3 kmph but can cycle it at 12kmph using the same level of effort, you can see there's a factor of about 4 in the distance for the effort. Conversely, it will take you about 4 times longer to cover the same ground by running as cycling, so you need to cycle about 4 times further (or more if there are downhills where cycling becomes vastly more efficient than running) to get a similar expenditure of effort.
Scientifically, it's more complex as Jimbo's wild and woolly posts don't hesitate to indicate
Fiona N said:Hi Fay
