Tin Pot
Retro roadsters are compliant AND cool![]()
:facepalm:
Can reflectors be fitted to shimano spd sl pedals?
Genuinely never had this compliance problem as I have only trained during the day.
Does it say anything about pie plates? Or use of the inner chainring?So bikes must look really uncool to be compliant.
when is that exactlyNot required in poor visibility, only required between sunset and sunrise (although it would be wise).
GC
bearing in mind refraction etc .Do they work in a more suitable way than the compliant ones?With my current setup my bike is fully compliant with the lighting regs. In fact they are to STVZO (Straßenverkehrs-Zulassungs-Ordnung) standard so exceed the British requirements. No surprise really as it's a new bike bought from a German outlet online.
I have additional non-compliant lights.
GC
As a driver as well as a cyclist I agree that yes, a steady light allows better judgement of speed/distance, and indicates the presence just as well as a flashing one. With a flashing light, even in conjunction with a steady light, speed/distance is more difficult to judge. A couple of very small lights on a bike with a drakly dressed rider is VERY difficult to see at all, even at dusk. Size matters!I would feel uncomfortable with one light in case of failure, and drivers seem to be able to judge speed better with a steady light.
I don't know who MRJ isJust as a question I don't know the answer to, probably Glenn or MRJ will (or its been raised in this thread that I've not read through)
Has the BS standard or not of lights ever successfully been a mitigating factor in a driver's defence against running a cyclist down?
but I don't know the answer to that and I suspect it's not on the public record because if it's either a good or useless argument then it won't have reached court. It would probably be recorded at the Motor Insurer's Bureau, but we can't search that for case outcomes, can we?No worries. I think the main problem with non-BS lights is having to choose between not being able to see properly if the light is aimed downwards and being an anti-social nobber dazzling other cyclists if it's not. BS and K lights have much better shaped beams, so you can see the ground a decent distance ahead but it's only a be-seen amount above the horizontal.Thanks for the comprehensive reply, I imagine it is an unlikely acenario or would be cited regularly when lights come up in this context![]()
In theory, any police officer could fine you for not having proper lights, but that's slightly undermined because all the cycle police I've seen are using non-BS pathetic low-end cateyes. Criminals! If you want to escape cycle police, just ride off somewhere unlit and I'd be amazed if they can see well enough follow at any speed.
